Ax 2012 ssrs Report not able to add table
Hi
Whenever i try to add Purchtable to purchaseorder report design , the fields are not shown in the report design .
Hi Rohit,
For SSRS reports first u create query right. In that query after u adding datasource the field properties should change.By default it shows unselected…
goto Query–>Datasource–>fieds–>properties–>Yes
I think this information will helpful to you
Actually that is when i need to create a new report but in ssrs reports (purchorder , we have report design ,there i guess we can add tables . but there on adding table iam not able to see the fields .
HI,
It is difficult to understand from ur above explanation. as per my understanding after adding the table to report data source node,
go to report ->data source-> table → field node property and set “Dynamics=yes” in that
