AX 2012 ssrs error :"Object reference not set to an instance of an object"
Hi folks,
I have dupilcated the PurchPurchaseorder Report but when i try to edit the report design i am getting the following error .
Can anyone please help me out with this issue.
Vikas Mehta.
Hi Vikas,
What’s u edit the purchOrder report use VS2010 ??
Regards
Toms
I am getting this error when i edit the data set …
Hi Vikas
I hope u have couple of instance in your server test and development .
if so then kindly stop the test report server for this timing and restart the dev AOS and Report server .
If same condition happen then full compile your AOT and put CIL .
when you are deploying your SSRS report in Visual studio after that u have to deploy that SSRS report in AOT also .
Sumit
