I have successfully created Store database and Offline database, and executed the N-xxxx jobs. The synchronized data can be found in store database. Everything is good so far. But when I was launching the POS client, I got the errors “The application could not be initialized” and “A system error has occurred. The application will close”.
The log is,
LSRetailPosis.PosisException: 1 —> System.IndexOutOfRangeException: There is no row at position 0. at System.Data.RBTree`1.GetNodeByIndex(Int32 userIndex) at LSRetailPosis.Settings.ApplicationSettings.LoadSettingsForTerminal(Terminal terminal) at LSRetailPosis.Settings.ApplicationSettings.InitializeSettings(String[] args) at LSRetailPosis.POS.Program.Main(String[] args) — End of inner exception stack trace — at LSRetailPosis.POS.Program.Main(String[] args)
Please help. Thanks in advance.
