Hi there,
We were trying AX 2012 pre-realese environment. While deploying SSRS reports from PowerShell and also from AOT we are getting below error…
An error occurred : The specified directory service attribute or value does not exist.
If User Account Control (UAC) is enabled on the machine, close the application, right-click the application, and then click Run as administrator.
The deployment was aborted. You do not have privileges to deploy to server: bwircadbridge. For deployment, you must have administrative rights to the SQL Server Reporting Services (SSRS) server. Contact your administrator to deploy.
However, we are sure
We disabled UAC
The used logged in to the server has an Local Admin rights.
Any clues to fix this issue?
Thanks in Advance,
Loganathan S
