Hi
When we try to deploy the RDLC report from Visual Studio 2010,Its giving the error as
Error 2 An error occurred : Access is denied.
If User Account Control (UAC) is enabled on the machine, close the application, right-click the application, and then click Run as administrator. C:\Program Files\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 466
Error 3 The deployment was aborted. You do not have privileges to deploy to server: xxxx. For deployment, you must have administrative rights to the SQL Server Reporting Services (SSRS) server. Contact your administrator to deploy. C:\Program Files\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 466
Can anyone pls. suggest a solution ?
