AX 2012 R3 Task recorder error
I configure the task recorder for basic recording in R3 and it working fine for a while and then system started giving error and now it doesnt shw me the space to create a new node… please refer the attachment and help…
I cant create new node or access the old ones
ERROR while crating new node:
FormTreeItem object not initialized.
Stack trace
(C)\Classes\SysTaskRecorderHierarchyTree\buildSubTree - line 68
(C)\Classes\CCFormTreeDatasource\expanding - line 4
(C)\Forms\SysTaskRecorderPlus\Methods\saveLeafNode - line 95
(C)\Forms\SysTaskRecorderPlus\Designs\DesignList\CreateParent\Methods\Clicked - line 8
What it you switch to another Framework/Industry?
I believe that this particular error is only the consequence of not having a tree control to add the new node into.
Didn’t you get a different error before?
no, even if i switch to another Framework/Industry it doesnt work … can i reset/fix the issue…
Didn’t you hide it? It would explain the problem, although it doesn’t fit into your description.
Right-click the empty space and if you see Show > FormTreeControl (or maybe some other control), use it. Or choose Personalize, then the Reset button and reopen the form.
thanks Martin, tree structure is visible now and also working fine with new Framework… thanks a ton
