Hi
can any one help i want to print Customer Sales Invoice Direct to Printer without print screen
by default it goes to print screen .
thanks in advance
Hi
thanks in advance
Sales invoice report uses print management, so you can configure defaults there (Accounts receivable > Setup > Forms > Form setup). Find details in Set up print management for a module [AX 2012].
hi Martin … i tried this process but did not worked it still goes to the Print screen … is there any code need to be modified ??
Sure, you can debug the code to see what’s the problem.
