AX 2012 R3 data import error message!!!!!
Dear All, we are trying to import the demo data in ax 2012 r3 and while running the DP file in command promt we are getting following error message any help will beapprciated!!!
Please show us the path you used.
Make sure you have the DemoData for AX 2012 R3 and the DIXF Tool (to import data) in the same path.
Hope this helps.
Thanks.
HJ
Dear Harsha I have resolved the issue by retrying the whole steps again and again…not sure where i missed something issue is resolved now…
after MicrosoftDynamicsAX give the ServerName\SQLInstanceName (… MicrosoftDynamicsAX DemoServer\SQL2012
