AX 2012 R2 Synch Error
Hi All
We have recently installed AX2012 R2 on New Server.Here i have created a new Var Model and doing all customizations.Suddenly when i am creating new field in Table Say CustTable…or any customization i am getting error as follows and the same Synch Error is Increasing with No.Please find the screen shot below and help me out in cracking it.
Thank You
Regards
HS Reddy
I think you have to apply CU7 update to your environment.
lots of compiler error also we will get in AX 2012 R2, try to apply cu7 update and see.
hope this will help to you.
Hi axsan
we have already installed CU7 and i have checked once again as per your suggestion.please help me out in cracking this.
Thank You
Let’s take a closer look at the first error, for instance. It says: “There is a field mismatch in the union query. Field CarrierName is not compatible with field Name”. So you should go to the view (TransportationAllParty), find the fields and check their properties, especially StringSize. It’s probably defined in data types DirPartyName and WMSCarrierName.
