AX 2012 R2 Retail Channel Schema
I just discovered that the Retail Channel Schema of the type AX 2012 R2 POS isn’t like it’s supposed to be. It includes the same location tables and location table Fields as the AX 2012 R2 Online Channel schema type. That means a lot of Fields are missing.
Is there a way to fix this, another way than manually add it?
