I run the class sysdatabasetransdelete in AX-2012. All my transactions has been deleted from journals but these transactions are available in main account posted transactions. Kindly suggest how I will remove them.
Regarsd
Regarsd
There is no code in SYS(Classes\SysDatabaseTransDelete) which deletes the records from
\Data Dictionary\Tables\GeneralJournalEntry
\Data Dictionary\Tables\GeneralJournalAccountEntry (posted transactions)
But i can see in latest Cumulative Update that there are changes in this class which are doing this job.
I wont say to go for a latest CU for this. But if you have an instance of that you can see the changes and make those in your current.
Hi Kranthi ,
My client is using the AX 2012 R2 CU7 , in this case if i want to delete all the Posted transactions against G/L , vendor , Cust , Inventory , Indian taxes tables , what is the best solution ?
SysDatabaseTrans would not be of much help for deleting the transactions in AX 2012( as many tables are company specific and all the scenarios were not handled).
Create a definition group by choosing the relevant table groups (http://technet.microsoft.com/en-us/library/aa834357.aspx)
export it and import it into a newly created company(rather than deleting the existing company transactions)
Hi Kranthi,
Thank you for the reply.
a) Can you explain what i need to export and import ? Explain with an example ?
b) Apart from these is there any other solution in AX 2012 R2 CU7 ?
Thanks in advance.
Any inputs ?
Hi ,
According to MS: http://msdn.microsoft.com/en-us/library/sysdatabasetransdelete.aspx. The new method (SysDatabaseTransDelete.deleteGeneralJournalEntryTable Method) is added in SysDatabaseTrans so technically it should work,
Othewrise need to use Data Import/ Export by creating Definitiion group without transactions tables (guide in Technet page by Kranthi already)
