I have installed AX 2012 R2 and could successfully finish upto CIL compilation.
Since my system is empty, and would like to have some demo data, i downloaded it from customer source. I managed to overwrite the 2 databases successfully. The one which has the data and the model database.
I opened the userinfo table and deleted all records except the ADMIN one and then i edited it for the fields like SID, networkalias, domain etc…
(I had did this perfectly on AX 2009 many times and it worked perfectly).
Now when i try to start the Service, it gives error, when i checked in EVent log,
“Object server 01: Fatal SQL condition during login. Error message " The internal time zone version number stored in the Database is higher than the version supported by the kernel(4/2). Use a newer Microsoft Dynamics AX Kernel”
Seems your AX Env. CU does not match with the environment where the Contoso Dataset has been created. (e.g. You might have CU1 and the Contoso datast for CU6 or vice versa ).
At least i had once the same issue when I copied a CU6 db and restored in the CU1 Database.
So, I would say just update your env. with CU 6 and test the database.
i am facing the same issue let me know what exactly steps you did to remove
