I have created a inbound port with file system adapter. I have a XML message set file with 47000 customers. I want to create these customer, hence when i put this file for processing i get the below error in the exception log.
Cannot select a record in Party relationships (DirPartyRelationship). Name: 0.
Deadlock, where one or more users have simultaneously locked the whole table or part of it.
Note: I have the parallel processing enabled on the port.
Also there is only one batch AOS.
Also i have seen the AIF macro and wanted know if any changes for the below would help me.
#define.MaximumInboundParallelMessages (1000)
#define.MaximumOutboundParallelMessages (1000)
#define.MaximumMessagesPerBatchTask (100)
#define.MaximumMessageSetsPerBatchTask (10)
Thanks in advance.
