ax 2012 purchase order posting classes
confirmation-purchpurchorderjouranlcreate
reciptlist-purchreciptlistjournalpost
packingslip-purchpackingslipjournalpost
invoice-purchinvoicejournalpost
these are posting class will hit while posting your po with confirmation,receipt list,packing,invoice
thnks
For more information go through the white paper ‘Using_the_refactored_Formletter_framework_AX2012’
http://www.microsoft.com/en-us/download/details.aspx?id=20864
where the Po Confimation Update and data insert in vendPurchOrderjour table?
\Classes\PurchPurchOrderJournalCreate\createJournalHeader
hi,
i create one table "ExemptionPurchRefernce ", when i confim the PO automatically insert the PurcTable Datas insert into My table,
i try these code but it should not insert
Note: My code in Bold,
protected void initJournalHeader()
ExemptionPurchRefernce exemptionPurchRefernce;
//ExemptionTable exem;
[journalNumber, voucher] = this.getNumAndVoucher();
vendPurchOrderJour.clear();
vendPurchOrderJour.initValue();
vendPurchOrderJour.ParmId = purchParmUpdate.ParmId;
vendPurchOrderJour.PurchaseOrderId = this.getJournalNumber();
vendPurchOrderJour.PurchaseOrderVoucher = this.getVoucher();
vendPurchOrderJour.PurchOrderDate = this.updateDate();
if (!purchTable.selectForUpdate())
purchTable = PurchTable::findRecId(purchTable.RecId, true);
if (this.proforma())
VersioningPurchaseOrder::newPurchaseOrder(purchTable).createApprovedVersion();
else
VersioningPurchaseOrder::newPurchaseOrder(purchTable).confirm();
vendPurchOrderJour.PurchTableVersion = PurchTableVersion::findLatest(purchTable.PurchId, purchTable.DataAreaId).RecId;
vendPurchOrderJour.initFromPurchTable(purchTable);
vendPurchOrderJour.setDocNum(purchTable);
vendPurchOrderJour.InterCompanyPosted = this.parmInterCompanyPosted();
ttsBegin;
exemptionPurchRefernce.PurchOrderNo = purchTable.PurchId;
exemptionPurchRefernce.VendorAccount = purchTable.OrderAccount;
exemptionPurchRefernce.VendorName = purchTable.PurchName;
exemptionPurchRefernce.VendorCurrency = VendTable::find(purchTable.OrderAccount).Currency;
exemptionPurchRefernce.Status = ExemptionStatus::Reserved;
exemptionPurchRefernce.insert();
ttsCommit;
hi ,
is u r debugger is getting hitting ??
thnks,
srikanth.
This code will execute in IL, you should generate an incremental CIL inorder to have your changes effected.
HI,
No debugger is not hitting …
ramanujam
HI ,
GO to Tools >Option> developement > uncheck the execute busniess opertaion in cIL
IT IS A TEMPORARY SOLUTION , OTHER WISE U NEED TO RUN THE CIL COMPILER AND U SHOULD NT GET ANY ERROR
THAT TIME ONLY U R debuuger will HIT
THNKS
SRIKANTH
It will work
