I would like to know whether it is possible to configure Time sheets as DAILY instead of Weekly.
I understand that AX 2012 R2, does not allow Time sheets to be set up as Daily.
Any work around?
Regards
Thomas Philipose
Any work around?
Regards
Thomas Philipose
Hi Thomas,
It is possible to create the periods and then split the periods so you would have a period per day. This is a bit cumbersome.
When you are using weekly it is possible to create multiple time sheets per week. So it could be a procedure to create one per day and submit per day. In the fact box the system will show totals per week also when you have split it on several time sheets.
