hi,
I use AX 2012R3. How should I find LedgerDimensionDefaultAccount in inventPosting table ? There is many capabilities for setup account. Is there any helper class ?
Best regards
Jacek
hi,
Best regards
Jacek
Are you trying to extract a ledger account from the LedgerDimension? If so, you’ll have to probably create a custom class and use these classes
You can get additional info by checking how these classes work:
Thanks for reply s3rg. There can be many combination for account table, group, category. I have to find account for Item. I can compare this to PriceDisc class. There is method findPrice and it check all combination. How can I do it here?
