ax 2012 : how to view select from query object
I want to see the resulting select of a query that is store in the AOT.
I tried the foillowing code;
Query q =
new Query(queryStr(REG_CarnetCommande));
info(q.toString();o(q.toString());
But the resulting string is : "Query REG_CarnetCommande object 2bd2e480"
Get the same result in the value of the watch in the debug.
I want to copy paste the result into SQL server.
Anybody knows how i can get the resulting select ?
Thanks.
You won’t get exactly a T-SQL query, but you can fix your code by this:
info(q.dataSourceNo(1).toString());
Thanks Martin,
Once again you solved my problem.
