Ax 2012, how to set simple properties of form with the help of class
In Ax 2012, how simple properties of form, field,design etc handled by class,
Could you try to explain once more what you want to achieve and what’s the problem?
I have two enum field and around 20 lookup field in a simple grid, now depending upon the value of these two enum, other lookup field may changed, enabled or disabled.
I want to do this with the help of class. Is it possible ?
Please Help
It seems that nobody understands what exactly you need, therefore nobody can give you any answer. Tell us what you’re trying to do, what you were able to implement and where you got into troubles, show your code if helpful etc. and you’ll have much better change to get an answer.
