ax 2012 how to create purchline for same purchtable purchid through code
hi all
i am trying to insert the purchline for the same purchtable -purchid
while inserting it is giving an error that record already exist
code as follows:
localinventdimid.inventsiteid = inventsiteid;
inventdimid = inventdimid::findorcreate(localinventdimid).inventsiteid;
purchline::initformpurchtable(purchtable);
purchline.createline(true,false,false);
please help if any body know.
thanks,
srikanth
Debug and check whether the line number gets properly updated.
Generally initFrom* methods will not be static
hi kranthi,
i am increment the line number in the code with 10 ,
is this write way to do …
thanks,
srikanth
Hi Srikanth,
You did not mention AX version.
But have a look under Purchline table > indexes. In AX 2012, there are at least 3 unique indexes. Make sure your honours all these conditions.
For creating purchase line records, you may want to consider using ‘AxPurchLine’ class. Example here - http://shrishailtechnologies.wordpress.com/2012/04/27/ax-2012-x-code-to-create-and-post-purchase-order-invoice/
HI harish,
it is version of ax 2012 , i am able to create line while incrementing the line number by 10 , is this write way to do ,
please guide me if it is wrong
thanks,
srikanth
Hi Srikanth,
PurchLine purchline;
purchLine.initFromPurchTable(purchTable::find(“your purch id”));
axPurchLine = AxPurchLine::newPurchLine(purchLine);
axpurchLine.parmItemId(“itemid″);
axPurchLine.parmPurchQty(10);
axPurchLine.parmPurchPrice(100);
axPurchLine.doSave();
Try this.Hope it will solve your problem.
