Hi Giunea,
I am trying to import data from excel to ax.
I did following steps
Click on Connection > Choose current server connection
Click on “Add Data” button > Add Data > Tick the General journal entries (which have already been setup earlier on in AX)
From the “Field chooser”, select the fields for journl header and entries
But when I select the added record and go to publish data, the “Publish Selected” is disabled
If possible for you can you please help me (guide me )to do this task, I have been search all over but could not get the proper solution.
Thank you.
