Can anyone help me from this error?
Dynamics AX 2012 - EP - Visual studio 2010.
Below is my step to produce this error.
Created a webcontrol in Visual studio 2010.
I added Datasource to the webcontrol
Added AXform
Added Wizard
Added AXGroup control
Added any BoundField
Error
Message: An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
Source: System.Web
Exception details:
The ‘Metadata’ property is read-only and cannot be set.
at System.Web.UI.ControlBuilder.AddProperty(String filter, String name, String value, Boolean mainDirectiveMode)
at System.Web.UI.ControlBuilder.PreprocessAttributes(ParsedAttributeCollection attribs)
at System.Web.UI.ControlBuilder.Init(TemplateParser parser, ControlBuilder parentBuilder, Type type, String tagName, String id, IDictionary attribs)
at System.Web.UI.ControlBuilder.CreateBuilderFromType(TemplateParser parser, ControlBuilder parentBuilder, Type type, String tagName, String id, IDictionary attribs, Int32 line, String sourceFileName)
at System.Web.UI.ControlBuilder.CreateChildBuilder(String filter, String tagName, IDictionary attribs, TemplateParser parser, ControlBuilder parentBuilder, String id, Int32 line, VirtualPath virtualPath, Type& childType, Boolean defaultProperty)
at System.Web.UI.TemplateParser.ProcessBeginTag(Match match, String inputText)
at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
