Ax 2012: Creation new values for standard dimensions
Dear All, I need to create values for standard dimension. I tried with following code
static void DEV_CreateDefaultDimension(Args _args)
DimensionAttributeValueSetStorage valueSetStorage = new DimensionAttributeValueSetStorage();
DimensionDefault result;
int i;
DimensionAttribute dimensionAttribute;
DimensionAttributeValue dimensionAttributeValue;
// Note that “Item” is not one of the default dimension,
// but DimensionAttributeValueSetStorage will handle it gracefully
container conAttr = [“Department”, “ExpensePurpose”, “Item”];
container conValue = [“00000028”, “Training”, “1000”];
str dimValue;
for (i = 1; i <= conLen(conAttr); i++)
dimensionAttribute = dimensionAttribute::findByName(conPeek(conAttr,i));
if (dimensionAttribute.RecId == 0)
continue;
dimValue = conPeek(conValue,i);
if (dimValue != “”)
// The last parameter is “true”. A dimensionAttributeValue record will be created if not found.
dimensionAttributeValue =
dimensionAttributeValue::findByDimensionAttributeAndValue(dimensionAttribute,dimValue,false,true);
// Add the dimensionAttibuteValue to the default dimension
valueSetStorage.addItem(dimensionAttributeValue);
result = valueSetStorage.save();
After running this job I get error “Unable to return DimensionAttributeValue record for 0000028”.
I need to insert value “0000028” for department dimension.
Please help to resolve this issue??
