Hello,
My client want to do consolidate the company. When I am trying to consolidate it I am facing following error message.
Please help to solve the issue.
Bhushan
Hello,
Bhushan
Hi Bhushan
Your screenshot does not show the Critical Stop error message. Is there another error at the bottom of the Infolog?
HI,
I believe you are using the “Use consolidation account” check box in the consolidation online form while performing the consolidation process.
Use this check-box only if you want the two companies main accounts to roll up into the default consolidation accounts setup in COA.
