AX 2012 China Localized Reports (Inventory In- Out Status)
Hello All,
We have a client requirement where they want a report which gives a summary of the Inventory between the selected period. Now I know that on hand report does the same, but they need a specialized report which has details of Movement/ PO/Transfer on the Receipt side and SO/ Adj/Transfer per warehouse/ Site and other dimensions on the Issue Side.
We have identified a report: the InventoryStatus_CN report which provides these exact details.
But, problem is that this is a China localized report and the Client is a US Client.
Also, we tried running this report and faced many inconsistencies with data. But i am assuming this is because we opened the Report from back end and in a non China localized Company.
Any one has any idea on this Report? If we remove the localization configuration, can we get a consistent report?
Please help out.
Thanks.
I don’t have any experience on that particular report, but sometimes is not only a matter of removing the association with a localization. Many of those reports, requires additional fields / tables. You most likely also need to check is table as such needs.
