HI all i have installed AX 2012 R2 then upgraded to CU6
then did DB restore of different environment
everything was fine DB restore went smoothly reports run smoothly
But before i go ahead and install EP i thought to complie whole application and do Full cill
again Compile was fine but FULL CIL Has errors please check screen shot below
as a solution i tried few steps 1. stop AOS 2. delete Xppil folder log files 3 started AOS 4. complied again
- Did Full CIL but the same error as screen shot please check
Thanks in Advance!!!
