AX 2012: Add project table fields in vendor request
I am working on a requirement where we want to have project id and project name field available on vendor request page. Client wants to track vendor request on project level and wants to enforce a workflow for such a request through project manager.
I added the fields projname and projid from projtable to vendRequest table, created field group, synchronized database and did a full CIL generation. When I try to create a new vendor request through enterprise portal I am getting the below error.
"An unexpected error has occurred. Field ‘Projid’ in FieldGroup ‘Project’ in Table ‘VendRequest’ does not exist in DataSource ‘VendRequest’ in DataSet ‘VendRequestCompanyRequestDetails’, this can be due to the datasource metadata node being out of sync with the corresponding table metadata node. Please check the event log or contact your administrator’
Please let me know what steps I have missed for this requirement.
I really appreciate your help. Thanks in advance.
Regards
Amrendra
I guess you will go to Enterprise Portal web page, at the right hand side, you should see Home > Administration, then -1- Refresh AOD -2- refresh data -3- refresh dictionary. it looks like the new code is not picked up by EP yet.
