Hi Everyone,
I created one webservice in visual studio 2008 and i write code for update method for only one record updated
but how to write code for multiple records update at a time using business connector in ax 2009
Thanks for advance
Hi Everyone,
Thanks for advance
Hello Naveen,
For one record update or multiple records update we will give only one service. Based on that we will update records at AX table from Visuval Studio.
For Example: I have a table with 3 fields
AccountNum Name State
1001 Ajay AndhraPradesh
1002 Vijay AndhraPradesh
Now you need to update State field you have to specify one parameter at where clause. for example
While select custTable where custTable.AccountNum == "1001"
in this scenario it will update only one record because you are specified AccountNum == “1001”
If you want to update multiple records at a time you have to remove where clause. for example
custTable.State = “AP”;
custTable.update();
it will update multiple records in the table.
like wise you have to modify your web service code.
Raman Kutala.
hi Raman,
thanks for reply but u passed values in code,but i am not to go for every time code and edit values,we have any alternative solution
Naveen, can you please explain clearly what you are expecting, so that i will try to give a better solution to solve your issue.
Raman Kutala.
Hi Raman ,
In ur Example u wrote code and mentioned values like"Custable.state = “AP”;right suppose i need to for update custable.state = “KA”,in this updation also we go for code edit “AP” to “KA”,right,
But i don’t want go for code edit ,i need any text box in this code, i need to pass values in this text box,when i click update button ,it can update ,is it possible in websevice project method
