I have the following problem:
I create a transfer order for one item with different dimensions in several lines.
When i create picking list i cancel one of the lines.
Then when i receive the order AX posts only the first row from the order.
When i try to do it again to post the other lines i get the following message.
The only way i can fix it is to change the values in еvent trans of the fields status issue, voucher and voucher physical.
Does anyone have any idea why this is happening? (AX 2009)
