I would like to split an invoice into two documents based on two site/warehouses.
I have tested this in my test environment where I have had the invoice check box marked under the split based on site.
So far its not an issue, my main question is what else would this functionality affect? I hope the financial side remains the same as well as the standard sales order process.
Well the summary update amalgamates transactions, so two shipments would produce one invoice. In your case if the shipments were from different sites it would create two invoices with that setting. It will not impact the sales order process except relating to the invoice and the only financial element is it would post per sales order, so arguably no change.
