ax 2009 services used to stop when I click on Import of AOT,I am not finding any solution for this to fix it.
Kinldy suggest/guide any way so that I can get rid off it.
Thanks .
Thanks .
Can you pls tell me which .Net version have you installed and one more thing either you are facing this problem in only client system or for all the system even server?
Regards
Abbas
I am using .NET FRAMEWORK VERSION 3.5, this is happening on both client as well as server.
Kindly provide me the solution since I am not able to get rid off it.
Thanks.
can you look into the event viewer and see if any events are logged during the crash. it may help sometime. Please post the error here too…
Thanx for looking into this query.
Here is the error which comes by clicking on IMPORT BUTTON:-
(IMPORT CLICK - SERVICE STOPS)
"Faulting application name: Ax32.exe, version: 5.0.1500.6491, time stamp: 0x4f611504
Faulting module name: Ax32.exe, version: 5.0.1500.6491, time stamp: 0x4f611504
Exception code: 0xc0000005
Fault offset: 0x0054b6ef
Faulting process id: 0x9cc
Faulting application start time: 0x01ce673482ba3c2e
Faulting application path: D:\Program Files (x86)\Microsoft Dynamics AX\50\Client\Bin\Ax32.exe
Faulting module path: D:\Program Files (x86)\Microsoft Dynamics AX\50\Client\Bin\Ax32.exe
Report Id: cf6652a8-d327-11e2-b1d0-001517f587bc"
Sometimes AX get closed after clicking on LABEL EDITOR while creation of new label,Here is the error:-
(LABEL EDITOR OPENING ERROR FROM OBJECT PROPERTIES - SERVICE RESTARTS)
Faulting process id: 0x17e4
Faulting application start time: 0x01ce67343034678e
Report Id: 886f4c7d-d327-11e2-b1d0-001517f587bc"
Kindly provide me the solution asap,I got stuck up due this.
Thanks.
can you plz check this.
Help-> About Dynamics ax → DIalog
Check the appl and kernel version and post those here
KERNEL VERSION : 5.0.1500.6491
APP VERSION : 5.0.1500.6491/IndiaPayroll 1.0.0
