hi,
Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x8004020F () which means: .
m using the SysMailer.sendmail() for sending mails from server. But i got the above error.
Ple anybody help me .
hi,
This is happening because your SmtpMail.SmtpServer is rejecting addresses.
Hi
code 0x8004020F means The server rejected one or more recipient addresses.
It depends on E-mail parameters in AX. If you want to send an email to an external recipient, user name from E-mail parameters form must be the same as sender. It doesn’t matter who is sender if recipient is internal.
