AX 2009 RU8 update failure
Customer has a number of AX 2009 SP1 AOSs, which required upgrade to RU8. One of them was successfully upgraded. But when AXUpdate is run for other AOS’s - it just stcuks in endless loop. Setup log shows following records repeating each couple of minutes. Has anyone encountered such problem?
Setup log for AOS that was updated successfully also had similar entries, but only a couple of times.
MSI (s) (80:3C) [08:00:39:797]: Note: 1: 1314 2: \sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64\
MSI (s) (80:3C) [08:00:39:797]: ConnectToSource: CreatePath/CreateFilePath failed with: -2147483648 1314 -2147483648
MSI (s) (80:3C) [08:00:39:797]: ConnectToSource (con’t): CreatePath/CreateFilePath failed with: -2147483648 -2147483648
MSI (s) (80:3C) [08:00:39:797]: SOURCEMGMT: net source ‘\sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64’ is invalid.
MSI (s) (80:3C) [08:00:39:797]: Note: 1: 1706 2: -2147483647 3: ObjectServer64.msi
MSI (s) (80:3C) [08:00:39:797]: SOURCEMGMT: Processing net source list.
MSI (s) (80:3C) [08:00:39:797]: SOURCEMGMT: Processing media source list.
MSI (s) (80:3C) [08:00:39:860]: Note: 1: 2203 2: 3: -2147287037
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (80:3C) [08:00:39:860]: Note: 1: 1706 2: -2147483647 3: ObjectServer64.msi
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Processing URL source list.
MSI (s) (80:3C) [08:00:39:860]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (80:3C) [08:00:39:860]: Note: 1: 1706 2: 3: ObjectServer64.msi
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Failed to resolve source
MSI (s) (80:3C) [08:00:39:860]: Failed to generate patch cache opcodes for: {F21D51AF-2BB8-4C1D-8272-08BDFC166403} product
MSI (s) (80:3C) [08:00:39:860]: Resolving source.
MSI (s) (80:3C) [08:00:39:860]: User policy value ‘SearchOrder’ is ‘nmu’
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Media enabled only if package is safe.
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Looking for sourcelist for product {F21D51AF-2BB8-4C1D-8272-08BDFC166403}
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Adding {F21D51AF-2BB8-4C1D-8272-08BDFC166403}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Now checking product {F21D51AF-2BB8-4C1D-8272-08BDFC166403}
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Media is enabled for product.
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (80:3C) [08:00:39:860]: SOURCEMGMT: Trying source \sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64.
MSI (s) (80:3C) [08:03:15:396]: Note: 1: 1314 2: \sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64\
MSI (s) (80:3C) [08:03:15:396]: ConnectToSource: CreatePath/CreateFilePath failed with: -2147483648 1314 -2147483648
MSI (s) (80:3C) [08:03:15:396]: ConnectToSource (con’t): CreatePath/CreateFilePath failed with: -2147483648 -2147483648
MSI (s) (80:3C) [08:03:15:396]: SOURCEMGMT: net source ‘\sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64’ is invalid.
MSI (s) (80:3C) [08:03:15:396]: Note: 1: 1706 2: -2147483647 3: ObjectServer64.msi
MSI (s) (80:3C) [08:03:15:396]: SOURCEMGMT: Processing net source list.
MSI (s) (80:3C) [08:03:15:396]: SOURCEMGMT: Processing media source list.
MSI (s) (80:3C) [08:03:16:473]: Note: 1: 2203 2: 3: -2147287037
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (80:3C) [08:03:16:473]: Note: 1: 1706 2: -2147483647 3: ObjectServer64.msi
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Processing URL source list.
MSI (s) (80:3C) [08:03:16:473]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (80:3C) [08:03:16:473]: Note: 1: 1706 2: 3: ObjectServer64.msi
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Failed to resolve source
MSI (s) (80:3C) [08:03:16:473]: Failed to generate patch cache opcodes for: {F21D51AF-2BB8-4C1D-8272-08BDFC166403} product
MSI (s) (80:3C) [08:03:16:473]: Resolving source.
MSI (s) (80:3C) [08:03:16:473]: User policy value ‘SearchOrder’ is ‘nmu’
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Media enabled only if package is safe.
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Looking for sourcelist for product {F21D51AF-2BB8-4C1D-8272-08BDFC166403}
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Adding {F21D51AF-2BB8-4C1D-8272-08BDFC166403}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Now checking product {F21D51AF-2BB8-4C1D-8272-08BDFC166403}
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Media is enabled for product.
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (80:3C) [08:03:16:473]: SOURCEMGMT: Trying source \sys45\ISSetup\sys18 issetup\Dynamics\DynamicsAX2009\Msi\ObjectServer64.
