I am new to ax 2009. I have an issue. That i have loaded few forms in test instance. but 3 days before some issue while on changing the configuration test instance stop working…I just click to enable debugger on ax 2009. it starting giving issues.
Now yesterday it was restored to original configuration after removing other new configuration… now the problem is that…
tables,forms created are not showing…I have xpo of that…but while I am importing I am getting errors… completely that fields are not available…illegal field.
What can i do next? kindly guide me and reply as soon as possible.
Have a nice day
Please, you have to be much more specific. We can’t help you until you do better job explaining your situation.
Please explain these points:
“some issue while on changing the configuration test instance stop working”
What kind of configuration change did you do?
What kind of issues occurred?
“I just click to enable debugger”
What does it mean and how it’s related to your issues?
it starting giving issues"
What kind of issues?
“it was restored to original configuration after removing other new configuration”
What exactly did you do?
“tables,forms created are not showing”
What does it mean? That your modifications are not in AOT.
“while I am importing I am getting errors”
What were you importing? Which exact object(s) give you the error?
- “completely that fields are not available”
What’s exact message? What’s the reference to object, property or line of code?
What you should do next is clear. Give us useful information instead of these vague statements.
