Ax 2009_Purchase order status invoiced
Hello,
I have the possibility to delete a purchase order (PO) with the status invoiced. I would like to restrict this action. I had already search on the parameter ( AP/setup/ parameter) There is a checkbox which permit to delete a PO invoiced ( the action that i can do without select it…)
Never mind, do you know how to “not have the possibility to delete a PO invoice”
Note: when the status of the PO is received, it is not possible to delete.
Regards
Accounts Payable - Setup - Parameters - Updates Tab
Safety Level of Invoiced Order = Locked.
Thank you Adam for you reply, it was very helpfull [:)]
