We are having problems with the number sequence cleanup in AX 2009. We have the Sales Order Invoice Voucher set as continuous and we are receiving the error : “Voucher SIV###### is already used as at date dd/mm/yy” when trying to invoice the sales orders on batch. The last successful run of the invoice batch job finished 2 minutes after the Complete cleanup started. Previously when this happened we just deleted the record from the list table and the problem was sorted, however this seems to be happening more and more now. If the clean up task and the invoice batch job clash could this cause a record that is already used to appear in the List table? Or is there a bug within the Clean up task of which I can’t see any history and doesn’t seem to run on a batch. Would it be best to run the cleanup on a batch job at night instead of the clean up task option within the number sequence?
Any thoughts or advice would be appreciated.
Steve
