Hi Friends,
I have a small doubt about license.
My license contains 15 user permissions .How many users to connect both ax client and EP.
Kishore.
Hi Friends,
Kishore.
EP users are licensed separately. Not sure how this impacts on actual clients, you would need to check what it uses, probably 1 which is the web connector.
Hi
If you are using AX 2009, You can create any number of user you want but at a time only 15 user will be able to use it, i.e. it is concurrent user licence,
About EP you need to check whether you have taken licence for that or not if yes then same rule apply.
you can check Admin>Setup>Config>Licence information and see the web tab
Thanks & Regards
Rajesh
