Hopely you can help wit the problem below (AX 2009)
I want to import an permissions file (.asg) file and go to Administration->Setup->UserGroups.
I select the group and click permissions
Then i select the correct Domain and click on the [Import] Button
There comes a pop-up with windowsname Import, with only a [OK] and [Cancel] button, there is not a field to select the .asg file to import.
How can i solve this problem ?
Thanks for help
Rob
