I am working in ax 2009 for enable of cubes for web user.
while i am working on cubes, i am facing the following error.
Errors and Warnings from Response
Internal error: The operation terminated unsuccessfully.
Server: The operation has been cancelled.
Errors in the back-end database access module. The provider ‘SQLNCLI.1’ is not registered.
The following system error occurred: Class not registered
Errors in the high-level relational engine. A connection could not be made to the data source with the DataSourceID of ‘Dynamics Database’, Name of ‘Dynamics Database’.
Errors in the OLAP storage engine: An error occurred while the dimension, with the ID of ‘DATAAREA’, Name of ‘Company’ was being processed.
Errors in the OLAP storage engine: An error occurred while the ‘Currency code’ attribute of the ‘Company’ dimension from the ‘Dynamics AX’ database was being processed.
Your Help Highly Appreciated here.
Thanks & Regards
