AX 2009 Dialog
hi
i want to create a dialog that accepts a table name from the user. then i want to execute an sql statement with the table name based on the input. is there a way to do that? thanks.
static void testDialog(Args _args)
Dialog dialog = new Dialog(“Test”);
Dialogfield df;
df = dialog.addField(typeid(TableName));
if (dialog.run())
select * from [insert table name here]
i cant seem to pass the dialog input value into my sql statement. any ideas would be welcome. thanks
Hi, see the following solution:
TableId tableId;
Common common;
tableId = pickTable();
if (tableId)
    common = new DictTable(tableId).makeRecord();
    select count(RecId) from common;
Hi Martin,
is there a way to change pickTable(i) into a Dialog so it can accept user input?
thanks
Hi, it can be changed (it is placed in Global class in AOT), however you can also use your dialog - I used pickTable() to simply show another approach, which may not be ideal in your case.
