AX 2009 Databse log issue
Hi folks,
I’ve added new entry to database log setup for delete action for our customized CrediCardTable but it does not log any delete for the table. I compare the CreditCardTable to CustTable(we have delete setup log for it and it works) and not specific difference. SaveDataPerCompany is YES same as CustTable. Any idea?
If you are able to setup the data base log successfully, then there should not be any problem with the logging.
How the delete is happening?
Add a break point to \Classes\Application\logDelete and see if it hits.
possibility that at the time of company selection in wizard ,current company has not been selected.
