Ax 2009 - cannot connect to AOS instance.
the AOS service has restarted correctly. But if i open Dynamics Ax Server configuration manager, I see there is no instance available in the Instance drop down menu…
What could have generated this issue? Any idea?
Thank you in advance
regards
What exactly are/were you doing?
