I need AX 2009 Business Connector (C # project) to run the Complete transport
(Inventory management-> Common Forms-> Pallet transport)
Regards
And? What problem do you have with it?
I don’t understand how to describe this parameter at the end of this code:
ax.CallStaticClassMethod(“WmsTransportFinish”, “main”,param);
sorry I’m novice in business connector
main() method accepts an instance of Args class, therefore you would first create AxaptaObject for it and then pass it to the method.
Nevertheless the method doesn’t look like a good choice. It assumes that it’s called from a form, which is not your case, therefore the call will fail a little bit later. I would call appropriate method directly. (Note that I’m looking into AX 2012, not AX 2009 - it may be different.)
If you’re now to BC, you’re making it more difficult for you than necessary. Forget BC for a moment and write a job in AX doing what you want later to do in BC. It will make your debugging much easier. Only when it works, re-implement the same logic with BC.
