hi,
I would like to set fields in schema for inbound documents in AIF. I disabled default policy. On fields list for CustService, there are few fields which I can’t sets. Example custGroup, TaxGroup and so on. Some of this fields are mandatory in table but not all. Those fields have minOccur to 1. When can I set this properties?
best regars,
Jacek
AxdBase class (the base class of AIF documents) has methods setTableFieldAsMandatory() and setParmMethodAsMandatory() that documents can call to set additional properties as mandatory. (I’m looking to AX 2012 but I think it’s the same in AX 2009).
If it’s the case, you can simply removed calls to these methods from the document class. Just be careful, because there likely is a reason why they’ve been set as mandatory.
