i want a report which have two filtering field barcode=itemno
when report will be filter by both then report out look will be as like
Total itemqty--------------remainining qty---------available- Import(date and order no)
- 4 2
i want a report which have two filtering field barcode=itemno and warehouse code=itemledgerentry.locationcode.
location code------ total qty------------------remaining qty-------------available----------import(date and order no)
WHSFEIQREB----- 6-----------------------4------------------------------2------------------
ALCOTT-BAT---------4--------------------------4-----------------------------0-
i add dataitem as a item and data indentation as a itemledger entry table.
IF( Item.GETFILTER(Item.“No.”)<>’’) THEN BEGIN
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Item No.”, Item.GETFILTER(Item.“No.”));
END;
IF (warehouse<>’’) THEN BEGIN
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Location Code”, warehouse);
END;
this is in onaftergetrecord method
REPEAT
totalqty:=totalqty+“Item Ledger Entry”.Quantity;
reserved:=reserved+“Item Ledger Entry”.“Remaining Quantity”;
UNTIL “Item Ledger Entry”.NEXT = 0;
but it is calculation all when i do not want filter by location code. it must shown total quatntiy according to location code.
how can i do this?
I am not sure if i am really able to catch your problem here,
But for reporting what you call remaining qty. can’t you just use the inventory field on the Item table?
If you use the iventory field you can use the flowfilter to calculate the remainging qty for each location.
Or is the object of your report to show the remaining qty for every Item ledger entry?
Inge
i am doing this. but it does not show total quantity by location code.
OBJECT Report 50016 Available Items
OBJECT-PROPERTIES
Date=06.01.12;
Time=13:59:27;
Modified=Yes;
Version List=Monir;
PROPERTIES
DATAITEMS
{ PROPERTIES
DataItemTable=Table27;
ReqFilterFields=No.,Description;
SECTIONS
{ PROPERTIES
DataItemIndent=1;
DataItemTable=Table32;
DataItemTableView=SORTING(Item No.);
OnPreDataItem=BEGIN
END;
END;
CurrReport.CREATETOTALS(totalbylocationcode,“Item Ledger Entry”.Quantity);
END;
OnAfterGetRecord=BEGIN
//IF “Item Ledger Entry”.FIND([Which])
REPEAT
END;
SECTIONS
{ PROPERTIES
SectionType=Header;
SectionWidth=23550;
SectionHeight=846;
OnPreSection=BEGIN
CurrReport.SHOWOUTPUT(warehouse<>’’) ;
END;
CONTROLS
{ 1000000011;Label ;2850 ;0 ;2250 ;423 ;HorzAlign=Left;
CaptionML=ENU=Total Qty }
{ 1000000012;Label ;5550 ;0 ;2700 ;423 ;HorzAlign=Left;
CaptionML=ENU=Reserved }
{ 1000000013;Label ;8700 ;0 ;2850 ;423 ;HorzAlign=Left;
CaptionML=ENU=Available }
{ 1000000014;Label ;12150;0 ;9300 ;423 ;HorzAlign=Left;
CaptionML=ENU=Import }
{ 1000000015;Label ;12150;423 ;3300 ;423 ;HorzAlign=Left;
CaptionML=ENU=Date }
{ PROPERTIES
SectionType=Header;
SectionWidth=23550;
SectionHeight=1269;
OnPreSection=BEGIN
CurrReport.SHOWOUTPUT(warehouse=’’) ;
END;
CONTROLS
{ 1000000000;Label ;600 ;423 ;2250 ;423 ;HorzAlign=Left;
CaptionML=ENU=Warehouse }
{ 1000000002;Label ;3450 ;423 ;2250 ;423 ;HorzAlign=Left;
{ 1000000003;Label ;6150 ;423 ;2700 ;423 ;HorzAlign=Left;
{ 1000000004;Label ;9300 ;423 ;2850 ;423 ;HorzAlign=Left;
{ 1000000005;Label ;12750;423 ;9300 ;423 ;HorzAlign=Left;
{ 1000000006;Label ;12750;846 ;3300 ;423 ;HorzAlign=Left;
{ 1000000007;Label ;16050;846 ;6000 ;423 ;HorzAlign=Left;
CaptionML=ENU=Order No }
{ PROPERTIES
SectionType=Body;
SectionWidth=23550;
SectionHeight=846;
OnPreSection=BEGIN
END;
CONTROLS
{ 1000000016;TextBox;5700 ;0 ;2700 ;423 ;HorzAlign=Left;
SourceExpr=reserved }
{ 1000000017;TextBox;2850 ;0 ;2550 ;423 ;HorzAlign=Left;
SourceExpr=totalqty }
{ 1000000018;TextBox;0 ;0 ;2550 ;423 ;HorzAlign=Left;
SourceExpr=“Item Ledger Entry”.“Location Code” }
{ PROPERTIES
SectionType=Body;
SectionWidth=23550;
SectionHeight=1692;
OnPreSection=BEGIN
END;
CONTROLS
{ 1000000008;TextBox;3300 ;0 ;2550 ;423 ;HorzAlign=Left;
{ 1000000009;TextBox;6150 ;0 ;2700 ;423 ;HorzAlign=Left;
{ PROPERTIES
SectionType=GroupFooter;
SectionWidth=23550;
SectionHeight=846;
CONTROLS
{ 1000000001;TextBox;3000 ;0 ;3600 ;423 ;SourceExpr=totalbylocationcode }
{ 1000000010;TextBox;0 ;0 ;2550 ;423 ;HorzAlign=Left;
REQUESTFORM
PROPERTIES
Width=9020;
Height=3410;
CONTROLS
{ 1000000000;Label ;330 ;770 ;3080 ;550 ;InPage=-1;
{ 1000000001;TextBox;3740 ;770 ;3850 ;550 ;SourceExpr=warehouse;
TableRelation=Location.Code }
REQUESTPAGE
PROPERTIES
CONTROLS
CODE
VAR
warehouse@1000000000 : Text[30];
totalqty@1000000001 : Decimal;
reserved@1000000002 : Decimal;
totalbylocationcode@1000000003 : Decimal;
BEGIN
END.
RDLDATA
I want to calculate total qauanity by location code.
