AutoPopulating a field upon entering another field.
Hello all,
I have a Form who has two fields namely ‘ID’ and ‘Name’.
The table, which is the datasource of the Form, already has values corresponding to these fields.
In the form when I select the value in ID field, the corresponding Name value should automatically get populated in the Name field.
Will creating an autolookup help ?
Should I write any code ? If yes, where ?
Thanks a lot !!
This is already being discussed in a duplicate thread on another forum.
Rather then copying the same thing to more places, answer my follow-up question there.
and also have a look on this
http://dynamicsuser.net/forums/t/76861.aspx
