Automation Excel Macro
Hello!
Can you help?
How do I call from Dynamics NAV an Excel macro?
And the excel solver called built-in function?
Thanks in advance for your help.
P3
Hi, in order to call the solver from NAV, the only solution I found and that works fine is to record a Macro in the Excel file that activates the Solver, and then to call the Macro from NAV using this code:
xlApp.Run();
where xlApp is a variable of type Automation ‘Microsoft Excel 12.0 Object Library’.Application.
Hope this helps you,
Marco
What about executing a link, for instance:
navision://client/run?servername=192.168.1.3%26company=XYZ%20Inc.%26target=Form%20330%26servertype=NAVISION
is it the same how to execute VBA code from excel?
Hi marcoferrari.
is it works fine to call the excel macro 2010 ? . right now we also have problem to call the excel 2010 ( xlsx / xlsm ) from the navision FORM.
I tried to make link with code : C:\Hyperlink\ABC.xlsx but it is not works. the message " Hyperlink failed to find the target"…
but when we still use the excel 2007 it is works fine . now we have create a few Query transactions with excel2010 to end users.
I hope you can help me for this problem.
thank you
Alfian 98
