It’s a weird thing that I have a button (let’s name it as Button1) where its AutoDeclaration property is set to YES. This button is place in the first form and is a MenuItem Action button where it calls a class and runs a form - second form. In the first form I have a method that will refresh the entire form see my code below.
void refreshForm()
common curRec;
curRec = AJournalTable.data();
//Assume the condition will return true
if(AJournalTable_ds.isOK(curRec))
Button1.enabled(false);
AJournalTable_ds.refresh();
AJournalTable_ds.research(true);
AJournalTable_ds.reread();
AJournalTable_ds.executeQuery();
The method above is called and invoke in the second form’s class.
if (_args.parmEnum() == RunChoose::Run)
_args.caller().doRefresh();
When the second form closes, still the Button1 is enabled. Any idean from you guys?
