I want to ask if NAV can has a feature that Customer Statement of accounts be send automatically to them on email?
Lee
Lee
No
You need to customize using Mail Codeunit or SMTP Codeunit…
Hi Lee,
If you are looking for attachment to be send by email then you need to write few lines of code using smtp code unit (400) and achieve the desired output
Another is NAV have its own default feature to send the report via email as follows
Run your report then click on File menu → Send → Report by email
The output will be generated in HTML format and embedded in outlook message .wherein you can select recipients
