Automatic purchase order creation on inventory low or Zero
is there a standard functionality where i can create purchase orders automatically if there is low or zero inventory.
Welcome to DUG!!!
First of all you need to understand the standard functionality Purchase /Order Planning and need to set parameters on Item card.
Then you can run Purchase planning for creation of new PO on the basis of parameters.
For creation of PO automatically you need to set the functionality in Job scheduler with parameters.
First understand the order planning of Navision and then do modification.
