i am pretty new in Navision (vers. 2009). We want to take raw data like sales, material costs or inventories every month and automaticaly put it into an excel file. The question ist now about the possibilities to realise it with ODBC (Instead of implementing a cube).
What is needed to do it this way?
Do i need a Software to realise the query or is it enough to install the driver and write appropriaty query in excell?
It all depends on the values and where these are taken from - if you can give more detail then we can guide you.
The performance is hughly dependent on the data required, system setup, hardware so you wont know until you try. The point here is to be aware that it MAY have an impact and to take this into account by doing the update at an appropriate time.
kk, i gonna keep it in mind. Maby it is possible to make the update at night.
the needed data is: sales, capital, Increase in inventories, annual net profit, liquid assets, order balance, Marketing expenses and so on.
Its desirable, that it can be automatically writen in one excel file without extra license costs. So i suppose the solution with ODBC should be the best here
It sound like you will be taking summarised values off the G/L Entry table which is typically a very large file. Have you considered build an account schedule, exporting to Excel and linking in the existing Excel sheet to the account schedule output.
actually a good point, some later i want to expose the different (and better) possibilities for our projekt (XMLPort, Report, potentialities of the RolesTailored Client etc.). So maby i gonna come back to some of this points
